Greetings! This is my first post so please forgive any protocol violations.
I have a 2003 Ford F250 SuperDuty early PowerStroke 6.0L 4x4.
I am using the HP Tuner MPVI2 Pro with VCM Suite 4.9.238.0.
I have the following issues...
1. The vehicle RPM is off by 50%. When I load the SAE RPM it reports correctly.
2. The FICM Main voltage reads the same as FICM Vehicle and is in the range of the control module voltage. When I check the FICM Main voltage via multimeter it reads 48vdc.
3. There is no access to the FICM Sync pid (0/1)
4. I can add a gauge for Fuel Rail Actual Pressure but there is no associated pid and no way to tell what variables need to be added to get the value. I can see HPOP.
5. There is a Injection Control Pressure that uses MegaPascal as the unit. What is this? Should I change it to PSI?
Thanks in advance for any assistance!
Doug
