Results 1 to 10 of 10
Thread: 2010 6.1 Procharged Challenger throttle not closing at high rpm
    Hey Guys, been chasing this on 2 separate cars. If you're at WOT above 5800 or so the throttle wont close. pedal position goes to zero but relative and commanded throttle only drops to 33% which is plenty to keep the car accelerating to the limiter! wall 219209 10 challenger ums 3 throttle still sticking.hptWall Throttle sticking no limiter active.hpl
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    584
    try disable pedal adaption.
    I have...no change.
    May 2018
    Germany
    584
    Try to reset all adaptives.
    Tuner in Training iCanuck's Avatar
    Apr 2020
    Vancouver, BC
    27
    Maybe modify the throttle body ramp rate.
    2007 300C 5.7L - Edelbrock Eforce (7psi), Comp Cam 268H,
    Mopar Ported Heads, 3.06 LSD Swap, 06 Coil Swap
    465hp @ 6200 rpm / 463 ft-lb @ 4700 rpm
    What throttle body is it. Any codes. I never adjust any of the tb tables for this tho it sounds interesting to use that route. I need to try that next time i get a boosted hemi in person.
    In any case i think your issue is going to be a charge pipe pushing the throttle body open
    Apr 2020
    20
    I am also having that issue.
    My T-body is a 90mm BBK.
    I thought that same thing, the forced air overpowering the return spring/gear causing it to stay open.
    Nov 2009
    All Around
    3,149
    you will need to adjust your airflow tables for the throttle
    Quote Originally Posted by SultanHassanMasTuning View Post
    The feed forward control or the airflow model?
    Nov 2016
    Austria/Europe
    46
    I?m struggling with the same problem and always get trouble codes throttle actuator, too much airflow dedected.
    300C AWD, 6.1 block, 392 stroker kit and now procharger kit
    300C, 5.7, AWD, 2005. now 6.1 Block, 428 Stroker Kit, Thitek Heads, Procharger D-1S, American Headers Longtube, Fox Catback, extra Oilcoolers, H&R thread chassis, Pedders Bushings, Pedders Sway Bar front, Speedlogix Front Strut Tower Brace+Matrix Brace Subframe Connectors, 245/40 20 Tires, Movit Breaks, 370x35 6 Pistons Front, 345x32 4 Pistons Rear
