Originally Posted by
TriPinTaZ
Yes but you have to consider that atmosphere is approx 14.5PSI (100KPA) depending on where you live. So the way it works in the ECU, 190KPA is allowing 90KPA over the 100KPA of atmosphere. So in reality this means the boost limit would be 190KPA-100KPA Atmosphere = 90 KPA or ~13psi.
If you're pullies are mechanically set to reach 15PSI then you should set Max pressure to 205KPA which is about 15.2PSI of positive manifold pressure. I typically set this value anywhere between 250 and 300KPA just as one of those little hidden flags in a tune so that I can see if any of my tunes make it back onto the internet somewhere. But in reality 205-210 is usually high enough for most stock blowers with a pulley.
