hi guys so i ahve a 2014 ram 5.7 and when the truck runs at idle in park and gear my idle afr would start out at 16 but after a minute when idle lowers the afr reads 29. need help.
How are you reading these AFR's? What wideband do you have and where is the sensor located? IF the engine was somehow running between 24 and 28 actual AFR, it would be running rough as!
If you made changes to your injector tables put them back to stock. give us some info. also set your wot table stock as well its too high on the low end and the part throttle table and wot therm table. Also set your knock retard tables stock. that's dangerous you can blow your motor that way... it's probably not reading right back there either. show us an idle log to see how lean it is.
The mods are cai, short tube headers, cat delete and straight piped. I had a jay greene tune, but I haven't messed with timing tables, because I'm trying to learn everything first lol and get familiar with the files. But I haven't touched injectors tables or any air or fuel related stuff I turned off rear o2 and cat protection because of cat delete but thats it. I'll send an idle log once I'm off work
Ok, I had sent a file with proper cat deletion in it. but i think the issue is that the rear o2 wideband is just reading open air it's not actually running lean.
One way to tell if it really is THAT lean is that it would be idling like 1200
