Editing 3d or 2d graphs
Hi all,
is there anyway in the VCM editor that you can achieve a smooth 2d or 3d Graph by changing multiple cells? The smoothing function in the 3d graph doesn't seem to achieve a full smoothing as wanted. Do you have to pull up every single point in 3d and 2d graphs?
As you can see with this graph, it has been pulled up a lot at just above idle and now it just needs to taper off as rpm and boost pressure increases.
Thanks in advance for your help
