Results 1 to 4 of 4
Thread: What is an acceptable amount of Retard? Suggestions?
    Aug 2020
    20
    Just curious what an acceptable amount of KR is. Seems everyone has different opinion on the matter. Personally I start to get worried when I see anything higher than 1-2 consistently. This is the 4th go around on my tune and still getting a considerable amount of KR....I think. I attached my logs and current tune. Mods are Long Tube, Catback, CAI.
    Any feedback would be appreciated. Thanks!
    13,559
    Give it more fuel if it's happening in PE, running 13.0 might be too lean and it doesn't like it. Try 12.3-12.5 on a NA engine.
    Check for vibrations/rubbing and check the motor mounts/transmission mount. If all is good you may be able to desensitize the knock sensors some.
    Aug 2020
    20
    Now that you mention it I have noticed some vibration lately. I think it is my headers/pipes hitting frame. Have not had a chance to get under the car yet. Do you think that could cause the knock?
    Aug 2020
    Petersham, MA
    134
    Quote Originally Posted by rkuper82 View Post
    Yep. Any weird vibrations can cause false knock (depending on the frequency of the noise).
    2017 Camaro SS, Whipple 3.0, Mast LT Black Label heads, 112mm TB, LPE BB HPFP & LT4+52% injectors, Fore Innovations triple pumps
    1059 WHP, 944 WTQ
