How do set up a mechanical throttlebody in HP tuners and what type of tps is needed to work with the stock ecu. Setup is going in a boat don't want to use stock pedal. Going to be using a crate 6 strategy on a 2013 truck pcm.
pedal follower
v-performance.pl/
facebook.com/veee.performance/
https://www.instagram.com/v.performance.pl/
Remote tuning:
[email protected]
+48 697276579
what are you going to do for dashpot? mechanica spring release or command a higher rpm for idle?
Havent made it that far yet. What do i do for a TPS since the Throttlebody and pedal will be mechanical?
