I have a 06 GTO H/C/I Holly EFI fuel rails LS3 injectors SBE 1 7/8th kooks headers 3.70 rear with trutrac level 6 FLT 4L65E 3800 circle d stall. I have been trying to get the idle to come down a little bit so I tried the base setpoint table with no luck I then moved on to base running air flow table and reduce that by 4 across the table. This brought the idle down to where I want it however it has introduced a idle surge on coast down and a crappy start up which seems odd. I am also fighting some tip in knock basically when PE is enabled. Yes the car is tuned by a reputable shop however I am trying to learn how to do this myself which is why I'm asking. Below is my tune and scan file does anything seem out of sorts? The coasting surge can be seen around 13:30 mark
Edit: I tried bringing the commanded idle down to no avail
