Results 1 to 2 of 2
Thread: Production grade ntk sensor .
    Aug 2020
    Somewhere hot in Arizona
    53
    Thumbs up Production grade ntk sensor .
    Question,
    setting up my new sensor in the scanner, i have installed and setup my AFR500v2 unit to the prolink on the 1st channel, i setup that part, an working on the transform selector.
    the HP data provide has the aft500v2 wide pre set.. an function states V/.3571428 + 6 = output.
    the ballenger tuning book.. states lambda (.618 - 1.098) = 0.618 + vout x 0.096
    Is the setting correct pre loaded? i have this unit set for lambda..
    and when i go to edit the parameter section for the chart/time, is there a change or specials unit already loaded for this as well.
    Thank you in advance
    -leo
    My ride.. 2009 Limited SRT8, Brilliant Black ⚫, Centerforce Clutch RIPx2 now Ram Clutches!, Full Adjustable BMR suspension, Solid mounted Cradle and Diff, DSS 1PC DS, Level 5 Axles, Belanger Headers, AFR500V2, Lowered, 180 Tstat, RonDavis Rad, Staggered tires.
    Don't look like this question was answered.
