Results 1 to 6 of 6
Thread: Generel AFR question how to log VE with filter
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    586
    Hey,
    I asked myself, is it helpful to log the fuel trims in ve table by settimg a filter to Lambda=1.
    Will this help to filter PE and DFCO out to get better values?
    stay tuned...
    Jan 2014
    Australia
    1,981
    no not really dfco is still lambda 1.0, u have to get creative to remove all the junk unfortunately or go old school as i do a bit and go thru manually
    Oct 2011
    Australia
    175
    You can set a filter such as commanded Lambda =1 , it will definitely filter out PE data, to filter DFCO is a bit trickier as DFCO when I tune is disabled, so to filter that data think about what your physically doing with 1) Accelerator Pedal or 2) TPS. Once you develop this filter you can start developing more intricate filters using TPS or Accel Pedal for steady state data collection as well, but as 07GTS has said you still need to manually massage.
    Jul 2020
    VIC Australia
    1,157
    This is the filter i use. Took along time to get it to where it is now. I hope you like it. Gets rid of all the junk in 1 hit.
    Options:
    If manual, remove the 2517 parameters
    Adjust the <3 up to include a wider range of throttle movements if needed.
    Remove the [6310]=6 to include idle
    Remove the [6310]=7 to include coast
    Filter:
    [2517.161.avg(500)]=0 and [2517.161.avg(-500)]=0 and (abs([50090.156.slope(500)])+abs([50090.156.slope(-100)]))<3 and ([6310]=6 OR [6310]=7 OR [6310]=9 OR [6310]=14 OR [6310]=15)=0
    Aug 2018
    294
    Yep. 6310 (Fuel trim cell) is the key to quickly getting rid of stuff or focusing only on certain things. One of the best ways to filter in my opinion.
    May 2018
    Germany
    586
    Thanks to all. Seems a little it easier to filter some things out.
    Extremely helpful in NB tuning.
