Results 1 to 11 of 11
Thread: New Hp Tuner User.. Gen 4 Cam Tune Help Needed...
    Nov 2020
    5
    Exclamation New Hp Tuner User.. Gen 4 Cam Tune Help Needed...
    I recently Purchased Hp Tuners to tune my 09 gmc sierra . it dod deleted and currently has a Comp cam part number:54-700-11 installed with texas speed long tube headers. no cats or rear o2 sensors. the trouble im having is idle tuning. i currently have the idle set around 800 rpms but the idle tends to surge constantly. can anyone on here give some input or guide me through the steps to correctly tune this truck without having cathostrophic engine fail . i have provided my tune file below and thanks.
    Jan 2019
    Australia
    81
    Do you have a log?
    Jan 2019
    Australia
    81
    Try this.
    Nov 2020
    5
    below i have provided what i believe is the correct log for the tune file i shared here on this forum earlier today. tomorrow i will test out your tune file and will let you know the results and thanks.
    13,565
    You still need to disable the rear o2 sensors, the cat test in the engine diag tab and turn off COT.
    Those must be disabled if you removed those parts. It can and will throw fueling off at random if it goes into a cat/o2 sensor test.
    Nov 2020
    5
    i tried the tune out and the truck idled better. the only problem now is that it has problems starting up when the engine is warmed up to operating temperature and when i put it in drive and give it some acceleration the engine loses power and goes into limp mode. whats the next step? i posted the log files below and thanks.
    Nov 2020
    5
    any suggestions?
    13,565
    Disable the stuff I said too.
    What code does it throw when it went into reduced engine power??
    You will need to learn how to tune the MAF and VVE with a wideband o2 sensor to correct the airflow/fueling model for the camshaft change.
    Nov 2020
    5
    it threw code p2135
    Apr 2022
    2
    Hey there did u have a tune to try for a 2009 Sierra with cam and headers and o2 sensor delete I saw unposted something but could not open attachment
    Apr 2022
    2
    Quote Originally Posted by JasonHSV View Post
    Try this.
