Is there a PID or some other indicator that will tell me whether the E67 ECU is referencing High or Low Octane tables (e.g., Engine/Spark/Advance/Base Spark Timing: High Octane and Low Octane tables)? Not sure if there is normally a sensor that indicates that or if it uses some other parameter(s) to determine which table to use. Any help is appreciated.
THANKS
G
