I just completed my 4.3l to 5.3l swap and cant get the truck to start. it will crank and start for a second and then die. I disabled vats in the system tab, set the dtcs for vats to no error reported. I have also did "write entire" when i flashed it with no luck. i am using the original pcm from the v6 to run the v8 but im pretty sure i swapped everything over. the truck was originally a v6 5spd and now is a v8 5spd. everything is stock on motor, all stock sensors, no cam, just a cold air and shorty headers. motor and harness was out of a 2005 silverado any help or suggestions would be appreciated. attached is the tune file.
2004 tonys 1500 v8 tune vats dtc.hpt
2004 tonys 1500 stock file v6.hpt
