Results 1 to 5 of 5
Thread: Dynamic air
    Dynamic air
    Have a question does anybody run in dynamic air through the whole rpm range instead of say only to 3900 rpm?
    Advanced Tuner ttz06vette's Avatar
    Sep 2008
    Charlotte, NC.
    242
    Are you asking if anyone uses a MAF tune with MAF enabled throughout the RPM range? If so the answer is “yes”.
    Aug 2018
    292
    I think the question is whether anyone pushes dynamic up higher than 4000 in a blended tune. I believe once you push it higher than 4000, it basically just uses the MAF anyway (if it's not failed). You can see it in a log if you compare MAF to VE to DynAir
    Aug 2009
    Calibrating
    3,373
    You can blend it as much as you want or high as you want! 19 zr1 does this
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Yes this is exactly what I’m asking about.
