I've been chasing some part throttle knock that I haven't been able to get rid of, and I finally saw what is going on in my last log. VCM scanner decided to crash when I tried saving it But the same problem is still in my last log file that I'm posting. At 2:04 into the log, smoothly rolling into the throttle, power enrichment stays off even when up into the 90kpa range for a short time. In the log that deleted, the issue was even worse and stayed out of power enrichment from 3000-5000 rpm with 75% throttle at .88 cylinder airmass and 90kpa for the full sweep causing a steady 3* KR. I just recently got HPTuners and am still confused on the Power Enrichment enable parameters on the Gen 4 stuff. If anyone can explain what tables need to be changed to enable PE sooner, or at a specific MAP kpa, I would greatly appreciate it. Looking at how my local dyno shop left most of these tables stock, I just can't wrap my head around what actually causes PE to enable. I never get measurable knock at WOT bc PE actually enables, I need to figure this issue out before moving on to dialing in my VVE table (as the dyno shop barely touched it).
Cam Specs:
235/248 111lsa 109.5icl at .050"
Custom timing map pt 3.hplPower enrichment coming in late.hpt
