Results 1 to 16 of 16
Thread: 2008 silverado ly5 need someone to look over my tune
    Nov 2020
    Knoxville Tn
    21
    anyhelp would be much appreciated my first tune any advice is welcomed.factory #2.hpt
    13,559
    The PE is too lean. You need to run around 12.5 commanded AFR and not 13.4 on a 5.3 truck engine.
    Don't mirror the timing tables either, the low octane table must have less timing in it. I would still have the IAT spark correction table remove timing at hot intake temps.
    Nov 2020
    Knoxville Tn
    21
    thank u im just learning any more help/advice would greatly be appreciated
    Nov 2020
    Knoxville Tn
    21
    newest tune will u look it over thanks factory #2.1.hpt
    13,559
    You went on the other end of the spectrum now.
    14.68/1.270 is 11.55AFR. Do 1.190 for a roughly 12.3ish AFR.
    Remove another 4-5 degrees of timing from the low octane table. Doesn't do much good if you have 24-25 in the high octane and 23 in the low octane, it would only remove 1 degree of timing. This is why the factory calibrations have 10-15 degrees of timing difference, because they want it to remove all the timing it can.
    Nov 2020
    Knoxville Tn
    21
    thanks look this one over please suppossed to be 89 octane tune lil performance daily drivenfactory #2.3.hpt
    13,559
    Tune files don't tell me anything, they just show what was changed and not how the vehicle is running with that tune.
    Scanner logs with all important channels is what you need to post. Needs all the important stuff like rpm, timing, knock retard, injectors, o2 sensors, fuel trims etc etc.
    Nov 2020
    Knoxville Tn
    21
    Ok will do thank u for ur help
    Nov 2020
    Knoxville Tn
    21
    new tune and log
    [ATTACH]105321[/ATTACH
    ]my current tune log.hpl
    please take a look advice needed
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,456
    From the scan, we can tell that your fuel tank sensor is erratic. Sorry to bust your balls, jsut letting you know that it didn't work. There is a BUNCH of things in there that you don't need---like the first half.
    2013 Silverado 5.3, 6L80k 8.8
    Nov 2020
    Knoxville Tn
    21
    What about tune bro
    Nov 2020
    Knoxville Tn
    21
    getting better i think still need advice beginner tuner
    my trucks current tune 87 octane 12-11-20.hpt please look over and correct me on whats wrong
    13,559
    The timing tables are still the same, shouldn't be like I talked about before. Otherwise it's pretty basic, not really sure I can tell you what is "wrong" because you own the truck and you need to watch the log files to see if anything stands out.
    87 octane limits what you can do but if the engine is stock you really can't mess anything up. It's hard to pick up magic power even with 93 octane, there just isn't much there without a larger camshaft.
    Nov 2020
    Knoxville Tn
    21
    how do i set timing tables for 93 octane and sir i really do appreciate ur help
    Nov 2020
    Knoxville Tn
    21
    and what cam shaft u recomend
    Nov 2020
    Knoxville Tn
    21
