Results 1 to 8 of 8
Thread: 2006 5.9 auto 4 inch diamond eye exaughst and cold air intake review please
    please take a look at my tune and let me know were i could improve tunejun14.2020.hpt
    Feb 2019
    Indiana
    135
    I would definitely lower the pulsewidth you dont want to exceed 3200us.. Also the there is some limiters still in places that might prevent full fuel
    NRunkle thank you, what limiters have you noticed that would prevent full fuel?
    Advanced Tuner MAIDENCR's Avatar
    Sep 2018
    Quebec,canada
    208
    did you put a 6.7 rail pressure sensor? if the answer is no how can you monitor 29kpsi of rail pressure?
    35deg of timing seam wild
    and like NRunkle said...over 3200 us is way to much!!
    03 cummins,175% flux injectors,dual cp3,s467.7/83 1.00
    Nv5600 with valair triple disc clutch
    Feb 2019
    Indiana
    135
    Quote Originally Posted by prestonbhamilton881@gmail View Post
    I usually set the high speed governors higher and use the rpm limiter table stop fueling where I want it.. Also your torque management tables arent maxed out.. && the like maidencr said the timing and rail pressure is a little high
    Sep 2018
    Quebec,canada
    208
    Quote Originally Posted by NRunkle View Post
    Need to be carefull with torque management...it destroy transmissions ahah
    Feb 2019
    Indiana
    135
    Quote Originally Posted by MAIDENCR View Post
    true.. but with the pulsewidth he was running I dont think he cares about keeping the stock trans alive hah
    Sep 2018
    Quebec,canada
    208
    In my tune all torque management are turned off...no need of that ahahah
