Results 1 to 7 of 7
Thread: New Guy - Scanner Not Logging RPM
    Nov 2020
    East Central Wisconsin
    5
    Hello all,
    Brand new to this site and HP Tuners. As per my sig, I have a 4.0L Stroked to a 4.7L, which is running on the stock ECM tune.
    Although it runs with no issues, there should be gains to be had by optimizing I would think.
    As the title states, I cannot get the RPM to log. I searched the issue on previous threads, but couldn't get it to work.
    I am attaching files requested my mowton in the sticky on scanner help. The Charts and Graphs folders were empty.
    On the TJ No RPM 11-27-20 log, it was in park and just revving the engine. On the TJ Log 3 WOT file, it was two runs at WOT.
    In the Channel configuration, if I load SAE defaults, nothing will log. I have to load Vehicle defaults for any logging to occur.
    As far as Jeep TJs go, it's a beast.
    Anyone that can help cure my ignorance, and get me going, it would be much appreciated.
    Jeep TJ Stock Tune 11-24-20.hptTJ Channel Config 11-27-20.Channels.xmlTJ Log 3 WOT.hplTJ No RPM 11-27-20.hpl
    1997 Jeep TJ
    4.7L Stroker
    Scat Forged Rotating assembly
    Russ Pottenger Head
    Comp Cam
    Bosch Injectors
    304HP calculated
    Nov 2020
    5
    Any help would be appreciated!
    Bill??
    1997 Jeep TJ
    4.7L Stroker
    Russ Pottenger Head
    Comp Cam
    Bosch Injectors
    304HP calculated
    13,585
    The only thing I can suggest is that you connect to the vehicle, remove the channel completely from the list, then click the vehicle tab at the top, scroll down to re-poll for supported parameters and add the channel back in.
    If that doesn't work then you will need more help from support.
    Nov 2020
    5
    Thank you for the input. I will try after work and let you know.
    1997 Jeep TJ
    4.7L Stroker
    Russ Pottenger Head
    Comp Cam
    Bosch Injectors
    304HP calculated
    Nov 2020
    5
    5FDP,
    No joy. I have submitted a ticket on this issue.
    Thanks for trying to help though!
    1997 Jeep TJ
    4.7L Stroker
    Russ Pottenger Head
    Comp Cam
    Bosch Injectors
    304HP calculated
    Nov 2015
    17
    Just went through this on our JTEC 1998 Durango.
    In the scanner click on the File folder with a gear (Recent Channel Configs) and use Vehicle Defaults.
    Click the Add Channel icon and add the high resolution rpm channel.
    Nov 2020
    5
    BBR,
    That did it (along with downloading the Beta version of the scanner per tech support.
    Thanks for the assist!
    1997 Jeep TJ
    4.7L Stroker
    Russ Pottenger Head
    Comp Cam
    Bosch Injectors
    304HP calculated
