Results 1 to 7 of 7
Thread: VCM Scanner not logging the same on two very similar GM E38's
    Aug 2011
    28
    I hook my scanner to a 2010 Z71 with a 6.2 and everything logs great on a generic layout. I can unplug it and hook right up in a 2011 Z71 with a 6.2 and connect to vehicle. It only logs 1 O2, no injector duty cycle and few others.
    13,565
    Does it to that even after re-polling all the channels on the 2011 truck?
    Aug 2011
    28
    I don't know what repolling is, but it does the same thing when I hit connect to vehicle. I'm going to attempt to post the data logs from each truck here.
    13,565
    Click the vehicle tab when connected to the truck, that is where you re-poll all the available channels.
    Aug 2011
    28
    Thanks a ton. I'll try that tomorrow.
    Aug 2011
    28
    data logs
    not sure
    Aug 2011
    28
    It worked. Thanks once again.
