Results 1 to 11 of 11
Thread: What is the RIGHT way to clear codes on thse things and do throttle relearn 2014-2020
    Baltimore, Md
    1,208
    because it seems like 10% success right if that in getting things to clear/reset. Theres multiple "clear DTC" buttons. Does it work properly on stable release and not the beta version I always seem to be on?
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
    Tuner in Training Speedy!'s Avatar
    Jun 2018
    interwebs
    49
    I've had hit or miss on clearing codes with either beta or stable release. Oddly sometimes rebooting the laptop solves it. Odd.
    Mar 2018
    Illinois
    873
    You can't clear permanent codes with HP tuners. The PCM will clear them if it sees data it likes or some same you need to reflash the PCM with a dealer type tool. As for throttle relearn, I find on GPEC2A PCMs the relearn in VCMscanner in special functions works but on older controllers I use the relearn in AlfaOBD...seemed to work on my buddy's 300 SRT8. Generally I clear all adaptives when I do a throttle relearn.
    Jun 2018
    interwebs
    49
    That's not correct. HPT clears codes on my Hellcat just seems to be hit or miss how many times I have to hit clear codes to get it to work.
    Mar 2018
    Illinois
    873
    Quote Originally Posted by Speedy! View Post
    So you can clear permanent codes with HPT? You must have a special edition because anytime I had O2 related codes that were permanent on my 2015 RT I could not clear them.
    https://forum.hptuners.com/showthrea...ary-O2-sensors
    I know HPT can't clear P1400.
    Jun 2018
    interwebs
    49
    1400 is a special case as it's reported from the BCM.
    Yes, I can clear permanent codes with HPT no problem, it sometimes just takes a few clicks of the button as it were. If the condition that caused the code persists then obviously it just comes back, however.
    Mar 2018
    Illinois
    873
    Well that goes against what others have experienced here including myself.
    As for P1400 my RT does not show this code in the BCM or PCM so it could be hell cats OS is different? I would kill to be able to get rid of permanent codes.
    Baltimore, Md
    1,208
    Is U1424 set by BCM too thats why Im not having any luck getting it to reset, and if so what exactly is it saying is wrong? Ive had a dead car for months because of this with nothing appearing to be wrong other than sets code immediate
    Mar 2018
    Illinois
    873
    That is a TCM code, implausible engine torque received which is not permanent and should clear but can pop back up if you drive.
    Baltimore, Md
    1,208
    Quote Originally Posted by Homer View Post
    This will not clear, soon as you start car you have no pedal. Cant for the life of me figure out whats going on
    Nov 2017
    816
    Set all the torque management back to stock and try again.
    If in doubt, multiply everything by 1.1.
