Results 1 to 2 of 2
Thread: Question on Bench Harnesses for GM 3.1L
    Nov 2020
    8
    Not sure if this is the right subforum but ...
    I have a 2000 Malibu with 3.1L V6 and would like to get a bench harness for the PCM.
    I see several units available like this for the LS1 V8
    The physical connector appears to be the same but I am not sure if the pinouts are different? Does anyone know if they are compatible?
    Apparently I can buy one with alternate pin configuration if needed but need to know what that config should be.
    Thanks.
    Nov 2020
    8
    Answering my own question.
    I found this which seems to confirm they are the same.
    https://download.efilive.com/Tutoria...20Tutorial.pdf
    I also contacted the ebay seller. He went ahead and tested on a PCM from a V6 and it works as expected. Just placed my order now.
