Results 1 to 11 of 11
Thread: E40 Fuel Density
    Aug 2009
    27
    E40 Fuel Density
    After building my 50% scaled tune for my 06 GTO I've been trying to correct the mpg calculator for my dash display but cant seem to find any kind of fuel density option anywhere. I'm using version 4.4.4 if that matters. Thanks.
    Tuner 5ft24's Avatar
    Mar 2018
    Sedro Woolley, Washington
    110
    Make sure your in advanced view.
    go to Fuel and the general tab. it's on the left
    Scale it the same as the injectors. If you scaled 50%, cut the number in half.
    from there make small changes. Once I did the half, I waited until I filled up again, and compared the reading to my calculated MPG. adjust by the percentage off and wait till the next fill-up.
    only took 2 fill-ups to get it pretty much dead on.
    screenshot
    https://drive.google.com/file/d/13ZG...ew?usp=sharing
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    FIC1000 shorty Injectors
    DW300C Fuel pump
    UPP GTO Auxiliary fuel system
    BoostDistrict LSA Conversion
    BTR Stage 3 PDS Torque cam and kit
    Kooks Longtube headers with High Flow Cat mids
    BoostDistrict LSA CAI with LS7 MAF module
    Mickey Mouse Catch Can
    Hinson 1/2" lowered Engine Mounts
    Magnaflow 3" Cat Back Competition Exhaust
    PLX DM-6 Wideband
    Turbo Technologies Full Flex fuel Tune
    Aug 2009
    27
    Quote Originally Posted by 5ft24 View Post
    screenshot
    Thanks. I am in advanced mode but i do not have that as an option for some reason. When i open a stock tune file it's there but Im using a 2Bar OS so im not sure where the disconnect is.
    Mar 2018
    110
    That's strange. Just took my tune, loaded it in, applied the 2 bar patch, saved it as a new tune file name, closed out, opened the new file and it's still there...
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    DW300C Fuel pump
    PLX DM-6 Wideband
    Jan 2014
    Australia
    1,984
    try using 4.8 update as alot was added to it that i noticed in mine
    Aug 2009
    27
    Yeah, I'll probably have to do the same thing. I'll load the new 4.8 and see if that works and if not ill just rebuild the tune from a stock file. Thanks again for all the help.
    Aug 2009
    27
    Thanks! I'll give it a shot.
    Mar 2018
    110
    I'm running 4.4.2 still
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    DW300C Fuel pump
    PLX DM-6 Wideband
    Aug 2009
    27
    Well, i tried loading the stock GTO tune and the car wouldn't start. It wouldn't even turn over so i loaded the previous tune and it started up just fine. I must've missed something when converting the tune file but im at a loss for what it could be since i copied everything over using the compare function. The only thing i can think of is im not using a GTO ecm so the GTO logic isnt being recognized?
    Mar 2018
    110
    The GTO ECM is specific to the GTO. Other E40 ECM'S don't run in the GTO
    Dec 2008
    on the Dyno
    1,825
    Edit your original tune file and verify/make sure the OS is the same and you didn't accidently overwrite your OEM OS file with another. Make the necessary adjustments in the original file, re-apply the 2bar OS and then copy your other settings over into the tune.
    However if it's displayed in the original OS it "should" also be shown with the custom OS applied.
    Located in Central Kentucky
    ShorTuning
