Results 1 to 3 of 3
Thread: 10R80 - Shift timing, Verification time.
    Nov 2020
    Hello there,
    Can anyone explain me what exactly does this map do ?
    By lowering this do you make shifting faster or is this only the timing window that the TCU uses to verify a gear change and if it goes further than this means it failed to change the gear ?
    Kind regards
    I've tried it and it's shifting faster
    Nov 2020
    Thank you Chevy, so the title is missleading and this is very close to the naming ford uses in their own definition.
    This map may somehow work as a parameter-factor on the "ramp torque rate maps" and result to the desired timing ( between some limits ofcource )
