Like i said, im looking for a stock 4L60E tune for comparison. ive tried a couple that i thought matched my set up as close as possible. im having problem where its not shifting out of first anymore. i haven ragged on it at all, havent even really done many WOT logs yet. so i wanna make sure i have a working tune to compare it to. if anyone can help with more id REALLY appreciate it since its my daily. i included the last tune with some of the recommended changes i received (as it reads on the file, i havent modified the VE table since the recommendations, and i believe the transmission side of it is from the first attempt where it was still shifting, albeit horribly, but at least would get out of 1st.
this is what i have set up
turbo 5.3l out of a 2007 silverado
LS9 head gasket
LS7 lifters
Small tubo cam (IntDur 232.1* ExDur 236.4* InstIntCent 110.05* ATDC InstExhCent 120.00* BTDC LSA 115.0* Overlap 4.2*)
Stock 411 ECU
Innovative Motorsports Wideband/boost controller
80lb Injectors
450lb fuel pump
Stock 4L60E
Speed by density; No MAF, EGR
CTS-V 3 BAR
