Hey guys,
So yes I am a novice tuner. ive got my MPVI 2 all linked up everything works (well I havent tried the wideband yet but) Ive got the latest version 4.8.7 installed. looking at the all the tables and everything is called different names compared to the GM tables and there seems to be many tables missing. I have "advanced" selected so I should see everything.
- Where do I scale for larger injectors?
- is the "VE" map im used to seeing on the GM stuff called "Base Fuel - Fuel Base-EGR Off"?? -found under the "Fuel - OpenLoop/Base" tab
I know I am being thrown off by the terminology but I dont want to screw something up either. There just isnt very much info out there on these JTEC PCM's.
Thank you very much for any help or direction you can provide!
Bryan
