Results 1 to 10 of 10
Thread: 2019 silverado not getting full throttle.
    Jun 2018
    609
    So this truck has been my new nightmare. Finally got it to idle solid and drive right. So we start some wot tuning and we're not getting wide open throttle. I adjust the vtt and everything looks lined up fine but we are stuck around 40-50% throttle. The max tq looks good and the peak tq is staying above it. The drive demand tables look good too.
    Oct 2013
    211
    Your MAF Hz reads abnormally low when you are going WOT... the values are higher at idle then WOT.
    Aug 2009
    Calibrating
    3,373
    It’s the way the e90 computer is setup... (it’s backwards, per say)
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jun 2018
    609
    Any thoughts why it's not going wot?
    Having same problem.
    Hacking the peak tq and driver demand at wot "fixed" it to 73%.
    Commanded is going to 100.
    Please help.
    Just did a 19 Corvette and it also only shows 73%, even though it is at WOT, so this might be a 19 thing to do.
    Jan 2021
    27
    I'm having similar issue. Can't go about 40 50% throttle. Everything looks great in the file. Just won't go above 100kpa. Car will not build boost. 19 z06 SC. I keep going through the tune but everything is fine as far as I can see. Fuel is spot on. Dynamic airflow is spot on. It's kinda weird. I was doing VVE closeloop fueling and was in a parking spot. Gave it a could slight revs in neutral to see how the recovery was and throttle response. Car revved to Rev limiter by its self to the point I had to shut Car off really fast. Now I'm not sure if it was limiting me before hand because I was never flooring the car until u got my idle and Driveability fueling done. Not sure if the throttle body took a shit on me. Any input on this???
    Aug 2009
    Calibrating
    3,373
    Quote Originally Posted by DCLTLLC14 View Post
    Don’t have my computer with me right now, but it’s the assigned gear table under tq management.. probably copy and paste and didn’t realize it changed.. out it back to stock and will fix the rev to the limiter on idle rev
    14 Gen 5 Viper
    Aug 2009
    Calibrating
    3,373
    Also as far as not going WOT, tq has to be off simple as that
    14 Gen 5 Viper
    Jan 2021
    27
    Quote Originally Posted by Ben Charles View Post
    steves log 2 hybrid wot throttle not opening 100%.hpl
