Watching right now! Wanna know what's crazy? Yesterday my friend's car said it needed an oil change when I was datalogging it to find out why it was idling erratically/killing like this.
A couple months ago I sent him on his way and it had no issues with a small overlap tune but did with a larger overlap (the same vct disable issue). He bought the car in May and it took me a few months to want to tune it for him. I know he's never done an oil change...
Recently though he told me it had started killing while idling in park. I figured it was because of the colder weather we have here and that the engine was cold, and an overlap tune would be harder but he was like nah it works fine when cold but once he drives for a while and stops, sits at idle in park (like lunch break at work), it starts doing it.
If it's the oil then my theory is: The ECM is pressure checking the VCT system and disables below X psi. At idle with thin oil (due to old or hot), pushing high cam angles for overlap causing more of a pressure drop under the threshold for the oil pressure. When VCT is disabled the phasers go back to home briefly causing it to quickly regain the needed pressure to re-enable and continuing the cycle of enable/disable.
When I tried 0/10 it didn't happen but 0/20 did. This has got to be the problem! It just makes too much sense with the behavior I'm seeing and how when I use a large angle (mostly with exhaust cam) it starts glitching out!
So what's the 'easiest' overlap angles that will use the least pressure at idle.. That's probably the solution + an oil change. lol
