Results 1 to 20 of 22
Thread: 2005 5.7 Hemi Comp Cam - Wont Idle
    Jul 2020
    15
    I have a 2005 5.7 hemi that will not idle due to my cam swap. It will run and start with throttle, stay running until you let off throttle. The cam is comp cam 112-700-11 specs 214-233 | .495-.492 | 112. I have long tube headers as well. Just a cam and long tube headers is my only performance mods.
    I have attached my stock tune file with a few codes disabled. Looking for help with just a base tune to make it start and idle own its own.
    codes-off-magnum.hpt
    Sep 2019
    16
    See if this will fire up and idle, man.
    May 2018
    Germany
    586
    you got less torque with the comp cam at low rpm....all is torque based.
    the o2 delay for LT is longer.
    Jul 2020
    15
    Quote Originally Posted by Trapper723 View Post
    thank you, i will load it today and report back to you. thanks.
    Jul 2020
    15
    Started right up, idled had some surge though. I put in R did ok, when it hit N it bogged down and died, and was hard trying to get it to start and idle again. I attached a trying to crank log here as well.
    trying-start-forum-tune.hpl
    Sep 2019
    16
    How long did you let it set and idle in park? Let it run awhile so everything can settle in some. And then see what the fuel trims are looking like.
    I?ll look at the log when I get home later.
    Jul 2020
    15
    not long, maybe 1 min. its hard to get it to start back and idle. ill try to get it to start again after it cools off some.
    Quote Originally Posted by sleepyvls View Post
    clear adaptives, let it run
    Jul 2020
    15
    I unplugged the battery for 30 mins, going to try to start it now.
    Jul 2020
    15
    Someone had said that It should probably easy to get idling. Bump idle to 800rpms, pull 20% fuel out of injectors or ve table in idle area, set min timing in idle area between -5/+5 depending on how loopy of an idle you want, and pull about 20% out the tq monitoring table, should fire right up and idle pretty decent and then Tweak from there.
    I have no clue where to adjust this stuff at.
    Jul 2020
    15
    Try this one and see if it does better.
    hard start, starts and dies. wont idle at all. has to have gas pedal pressed to even start. let off pedal and dies.
    Sep 2019
    16
    Man.. I thought for sure that it would idle on that. So worse than the first?
    Jul 2020
    15
    they are about both the same tbh, should I do a write entire or a write calibration only? been doing write calibration only. not entire. I know sometimes you have to do a write entire to get changes to take.
    Jul 2020
    15
    could you make a file with these changes
    Sep 2019
    16
    Post your original read from the car before you changed anything so I can see it.
    Both of those tunes I sent have work done to all those things.
    Jul 2020
    15
    posted above this message. thanks bud.
    Jul 2020
    15
    also, I do not have abs or traction control, this was a Hemi swap into a 05 magnum that was a 2.7 factory. cats deleted, no egr, no rear o2s, mds deleted.
    Jul 2020
    15
    No, motor was tore down and rebuilt though. I do not think its a mechanical issue. I'll try that tune later today.
    Jul 2020
    15
    Oh good lord, man haha. Did you run the swap any before the cam? Heres another shot.
    that tune did not work either really, check this one i made. it starts up easy, no throttle needed to start. but idles surges some and will die off. attached is tune and 2 log files. just trying to stop the idle surge and smooth it out.
    2005-magnum-base-tune.hpt
    base-idle-log-1.hpl
    spark-5-adv-log.hpl
