When I pushed in on the Button for 7 seconds the light on front of MPVI2 Interface started to flash... Then went to Laptop Bluetooth window turned Bluetooth on then scanned for MPVI2, found it then Pared it.. Wouldn't work until I Booted Laptop from Being OFF! This is called cold boot. Then I could read data fron ECM and it worked Flawlessly. This is Because a driver was silently installed and this driver can only work if you cold boot up.
Have Fun!
