Currently working on a 2020 gt A10. One thing I noticed is the stock OSS speed(@WOT) is 1700 rpm and the engine rpm that it shifts at is 7500rpm. Assuming 1=engine rpm and the first gear ratio is 4.70, then technically speaking it should shift at 7990rpm. But I?m assuming since the torque converter isn?t locked the engine rpm /= 1. Which means there?s a 6.33% slip between the engine input and the transmission output for first. Regardless of that, if you divide 7500/1700 you get roughly 4.41 as the ?first gear ratio? so say if I wanted it to shift at 8000, I would do 8000/4.41 and get an OSS rpm of 1814 rpm. Is this a correct assumption? I?ve been fortunate enough to only have to do manual 18+ up till this point.
