Results 1 to 10 of 10
Thread: 2017 L83/6L80 swap shift mph tuning
    Feb 2020
    35
    I would like to have my shift mph lowered, 1-2 and 3-4 takes too much mph to shift is there an easy way to do this? I have been looking at the tune but not sure what to change Thanks
    13,569
    You need to post the tune.
    Make sure the gear ratio and tire size is correct in the gear tire wizard in the edit tab. That must be correct before anything else.
    Feb 2020
    35
    tune
    lukeC10finaltune2020.hpt
    3;42 gears 30.5" tire
    13,569
    Fine the upshift table and just lower the mph for that gear at whatever throttle percent you want. There is not much to it.
    If at 20-40% throttle it's taking to much speed just drop the mph by 3-5 and see if that helps.
    Feb 2020
    35
    ok thanks
    13,569
    You'll have to adjust the downshift table as well. Don't want the upshift and downshift at the same speed or like 1 mph different.
    Feb 2020
    35
    so there is normal, pattern A, pattern B, and Hot how do I know what table is used?
    13,569
    Everything is normal outside of tow/haul mode.
    You can even log the shift pattern in the scanner too if you really wanted too.
    Feb 2020
    35
    gotcha thanks
    what did you come up with after tweaking it?
