I recently added a manual transmission and larger cam to the 6.1-based 7.4L hemi in my SRT8 Magnum. As I tune out the plethora of drivability issues (mostly with the throttle body range tables), I've been trying to figure out how PCM translates accelerator pedal voltage into throttle body voltage.
It seems to me the PCM computes requested torque from accel pedal voltage. Then it looks at current RPM, VE and the throttle body range tables to figure out how much throttle angle it needs to provide that torque. So what happens if you throw turbo spool into this? Does the PCM freak out, or is it all manageable somehow?
Everything would certainly be a lot easier if you could just map pedal voltage to throttle voltage, like a cable throttle... This wouldn't be great for an automatic car of course.
Thanks for any help. I originally wanted to get a Hellephant, but it doesn't seem like I'll be able to get my hands on one. So now I'm thinking I'll have my current block built for turbos.
