Results 1 to 12 of 12
Thread: RIFE IAT sensor
    Jul 2018
    4
    RIFE IAT sensor
    Hi! I was thinking about updating the stock GM IAT sensor to a Lo-AT Rife Sensor. I have a LS3 with a 2650 blower running E85, twin -10 meth, and an interchiller. I'd like to get a faster temp response to help with future tuning. Has anyone added this sensor and what exactly was upgraded in the tune? Rife has a 32 cell calibration table available. Just curious if anyone has gone down this path...
    TIA
    Michael
    I'm working on a gen 3 tune with the Rife Lo-AT sensor. Send an email to [email protected] and put voltage conversion worksheet in the subject line. Let them know you are working on gen4 stuff, not sure if gen 4 has the same pullup resistor as the Gen 3. They've been helpful to me so far. I haven't powered up up my sensor yet to see if the calculations are accurate.
    My screen shot is for Gen 3 stuff, not gen 4.
    Jul 2018
    4
    Thanks for responding! I actually did get in touch with them, nice group to work with. They gave me a value set to work with for the first set of values. Its pretty interesting to see how fast my IAT temperature moves around while driving, stopping, idling, and then moving again.
    Can you share the gen iv info? Planning to order this in the next day or two and need this.
    Jul 2018
    4
    here is the 33 cell Hptuner values that I used:
    R- 118 132 157 178 204 235 271 314 366 428 503 595 707 845 1017 1231 1500 1840 2276 2836 3564 4518 5781 7471 9756 12884 17218 23302 31963 44481 62863 90320 132092
    F? 345 335 320 309 298 287 276 265 254 243 232 221 210 199 188 177 166 155 144 133 122 111 100 89 78 67 56 45 34 23 12 1 -10
    Quote Originally Posted by a6d9cmro View Post
    Thanks! I got it installed last night and it appears to be reading correctly key-on engine off.
    Mar 2014
    1
    Quote Originally Posted by Just Chuck View Post
    I tried your table in the genIII 3-bar custom OS. It was limited to 284 degrees. Also, testing vs ambient, I had a difference. Thermometer in the garage reads 32, scan says 44. For giggles, I used my laser Thermometer on the intake and it read 44 deg. Torn if I should adjust this or let it ride. I mostly am using IAT to pull timing if my meth injection fails. Im closed loop SD non-complex otherwise. Using the rife to help avoid heat soak a bit.
    May 2016
    Canada, Halifax NS
    4
    Did this data set work for you with the Rife IAT sensor with a Gen III
    Dec 2022
    12
    where did you input this data?
    This is on Gen4/E67. IAT 1 or 2, depending on which one you replaced. Tables should be similar on gen 3 I believe.
    May 2022
    5
    For any future people wondering, the graph for the Rife standard IAT that *Just Chuck* posted a picture of is accurate to 0.2 deg F in my testing for the temp Vs % that gen 3 uses. My particular testing was with a P411 pcm. I dont see the need for adjusting any further as 0.2 degrees would be a drop in the bucket IMHO.
    Dec 2005
    Texas
    254
    Have a Gen 3 411 pcm and Rife sensor. Tried adjusting the cal for IAT but get message saying numbers exceed the max value. I also get a prompt asking if I want to override the max value. I click yes, but the numbers I'm trying to adjust go back to stock values. Anybody else have this issue?
