Results 1 to 9 of 9
Thread: 2020 Mustang GT 10R80 FMEM 6th gear on the dyno and the street
    Tuner Robert00MustangTurbo's Avatar
    Aug 2018
    TEMECULA, CA
    62
    Cobra Jet Intake Manifold
    Steeda CAI
    CFM Twin 67mm Throttle Body with JMS Throttle Max (If anyone has good TB Data for this throttle body or a Twin 65mm for the 2018+, please let me know!)
    E85
    Hello,
    I have here a 2020 Mustang GT 10R80 that is throwing a Wrench light in 6th gear on the dyno and stays on even with ignition cycles. Codes P0600 and P27B5 illuminates every time.
    I've tried putting everything in the trans back to stock, but no improvement. I even went and used the stock throttle body data and no improvement.
    I raised all the limits that I know of since in 5th gear the engine will spin to 8000rpms. Is there something I'm missing? I've searched through the forums but no concrete solution.
    I only hit FMEM in 6th gear. around 6800RPMs-7200RPMs
    6th gear FMEM Trans.hpl
    6 gear fmem patch removed.hpl
    5th Gear full pull no fmem.hpl
    Anthony 2020 Mustang gt E85 base 2.hpt
    Anthony 2020 Mustang gt stock file pulled.hpt
    Here are 3 logs and 2 Tune files, one modified and one stock.
    Thank you
    I had the same issues your facing your troubles are in the transmission tunning side you have to raise lots of limiters. such as lower clip, etc.
    Also 1:1 gear ratio is achieved in 7th gear in order to measure hp accurately.
    Feb 2016
    482
    u have alot problems throttle closing etc
    Aug 2018
    TEMECULA, CA
    62
    So after taking the time to carefully read the existing threads about the 10R80 on here and applying changes, I was able to stop the Trans FMEM, P0600 and P27B5 from occurring.
    I was able to finish calibrating the car on the dyno and made pretty good power and it's nice to be able to do a full sweep without interruption. On the street, I got the car shifting at 7800 RPMS from 2nd-6th.
    I am going to report back in 1 week to ensure the issue is fixed and post my findings here. Will be driving the car everyday.
    Dec 2020
    17
    What did you change?
    I?ve been messing around with my truck and it does something similar but doesn?t throw a wrench. It will short shift into 7th than shift back into 6th then back into 7th. Very strange
    It does exactly as commanded the rest of the gears 1st-5th
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    Quote Originally Posted by NA_F150 View Post
    if you want help make a new thread and post your tune and usable log file...
    Aug 2020
    armenia yerevan iraq baghdad
    i can do it to u same problem and i solve it
    Aug 2020
    mustang 2019 10r80 cobra jet
    bro u can use this file to solveur prolem
    Aug 2018
    TEMECULA, CA
    62
    Sorry it took quite some time to get back to this thread,
    I was able to fix the issues. it's all related in the trans side of tuning.
    There were more areas I had to work on to get it to stop.
    Attached is the file
    Joseph 2018 mustang gt procharger base 1.hpt
