Throttle window on Ecoboost
Hello all
I've noticed that I have a throttle actuation beetwen 2000RPM and 3000RPM reducing my torque constentely when I reach arround 150mbar of delta pressure between actual and desired. (arround 4.5 InHg I believe).
Do you have any idea if there are such limiter as delta turbo pressure?
Thank you!
Hi,
you can log the limiters with vcm scanner. If you need more detailed help please post the logs you did with vcm scanner.
Greetings
robby
Unfortunately vcm logger doesn't have much info on the latest 1.5 ecoboost 150hp
With forscan I could log desired and actual boost, and the only thing I could notice is that the delta between the two is high when throttle is closing
