Results 1 to 7 of 7
Thread: maf tuning 06 gt 4.6
    Jan 2020
    7
    whats the process to tune the maf of these things? ill admit im used to the GM stuff and this is a lil different i just wanna do it right. ill gladly help with any GM questions if there is any
    Dec 2020
    PA, USA
    52
    stock or aftermarket maf and is the housing changed? is the manifold/supercharger swapped out? would need to know where to start but ill post up some info tho.
    Area of stock MAF housing is calculated by using the formula for the area of a circle
    (Pi)((radius)^2)
    Radius = (1/2)(Diameter)
    Pi = 3.14159
    (3.14159)((old housing radius)^2) = answer for old
    (3.14159)((new housing radius)^2) = answer for new
    (Area of new MAF housing)/(Area of old MAF housing)= difference
    Multiply the entire MAF curve by difference and this should get you pretty close.
    Mar 2010
    New Orleans, LA
    630
    set up a histogram to plot stft + ltft vs maf voltage
    copy and paste the maf voltage scaling from your tune and try to hold each imaf point for as long as it takes for the o2s to control fuel and then move on to the next point
    exactly the same way you do GMs as well
    Jan 2020
    7
    Quote Originally Posted by decipha View Post
    my bad i know better lol, its aftermarket cai thats bout it, i appreciate the info, but is there anything i need to turn off like temp control or dfco?
    Mar 2019
    351
    Nope, what's been said here about initial setup and histogram tuning will get you spot on.
    Jan 2020
    7
    ok thank you guys for the info, and if yall have any other tips or info on these things ill gladly absorb the info lol, if yall need help on either the gm or dodge stuff im more than happy to help, im just a noobie on the modular stuff
    what intake do you have on the vehicle?
