Results 1 to 4 of 4
Thread: 6l80 how to reduce gear kick down
    I would like to find a way to keep the transmission from extreme down shifting when at 60-80%TP
    i.e. will be traveling behind another vehicle and want to pass while in 5th gear, pedal goes to 60% than trans shifts all the way down to 2nd and motor revs like mad. How do i get it to only downshift 1-2 gears only from the current gear of 5th or 6th?
    Feb 2016
    Texas
    534
    The downshift tab in the trans menu would be the best place to start. simply finesse the 5-2 downshift along with the 5-4 and 4-3.
    97 ext cab short bed silverado 5.7 411 swap, edelbrock 29135 intake, lightly ported 906 heads milled .035 thou. factory press in rocker studs & rockers, comp 787 retainers & stock locks, ls6 springs. Comp cams 08-503-8 T56 swap
    86 SWB crate vortec 5.7/th350 The wife's truck
    thank you!
    any recomemnded tuning points for the cells, i dont know which way to go with it?
