So the car is tuned, runs and drives good... overall. Have some questions though.
- These car's are MAF only, is it just that this year pcm doesn't have the best resolution?
- Car is in open loop only, i believe is like that due to LT negative trims can carry into WOT? Anyway to disable that? or? I'd like closed loop to function if possible.
Yes 07 S197 GT is mass air, not speed density, by default. It's designed to run closed loop feedback until you go WOT, which then switches to open loop based on MAF. What I always did was re-create the MAF transfer function with a new airbox. I had the Saleen airbox on my 07 GT and no one would share the Saleen tune file, so I went and built my MAF transfer function and it was spot on. Never had a problem.
