Results 1 to 19 of 19
Thread: 2020 Mustang GT - closing throttle on 3-4 shift - 10r80 - tq red > driver demand
    Advanced Tuner Justinjor's Avatar
    Jul 2011
    Tampa, FL
    275
    So took the shop car to the track for the first time last night. Car is a 2020 Mustang GT with 480 miles on the odometer. It made 440whp on my dyno and first pass down the track it went 11.9@119 as delivered from the dealer.
    The only change to the car is E85 in the tank and my quick dyno tune. Stock everything else.
    I was aiming for 7400rpm shift points given the power curve but wanted to see what it did with stock shifting schedule first.
    On the stock transmission shift schedule everything seemed ok. No throttle closing issues but only ~6800rpm shifts.
    Tweaked a few things and got it shifting right at 74-7500 which was ok but on the 3-4 i'm getting tq red >driver demand and the throttle was closing to 35% for a short time.
    Any ideas?
    Given the very stock nature of the car minus the fuel, I'd like to assume the torque model is basically correct so I'm not sure why the pcm is upset about.
    Log and tune attached.
    It just seems weird it's only on the 3-4 shift. I haven't found a glaring problem yet but I'm still digging.
    Log 1 goes with tune file 4
    Log 3 goes with tune file 6
    2020 Mustang GT Daily driver
    |Hellion Sleeper|10R80|Full weight, full exhaust, BABY seat in the back|
    8.3@167mph
    2014 Mustang GT
    |Hellion TT|Powerglide|Ignite114|
    6.87@200mph
    Jordan Performance and Racing
    Says in your log Trans Protect RPM Limit 7570. I suspect you are running into limits in ECM 6849 under Trans>General>Limits>Limit Initial. Also the polling speed on your RPM is very slow and you are not seeing the actual maximum RPM. Looks like a RPM limit for sure even tho I don't see the smoking gun.
    Torque Source: In Gear Limit
    Spark Source: Torque Control
    Trans Protect Limit: 7570
    Jul 2011
    Tampa, FL
    275
    Quote Originally Posted by Ranger Coyote View Post
    Good eye. Thank you!
    I'm not sure what happened but the polling speeds are all slow. I just noticed that.
    Thank you for pointing it out. Fresh set of eyes is killer
    8.3@167mph
    2014 Mustang GT
    6.87@200mph
    Jul 2011
    Tampa, FL
    275
    Next pass was log 7/file 7. I had already raised that limit initial up to 9000 and now trans protect limit is 7075.
    See anything else that looks suspect? I'm going to take a shower and dig over this file again. See if i can reset my brain
    8.3@167mph
    2014 Mustang GT
    6.87@200mph
    I think the slow polling is messing with your ability to see correct sources... There is a table that shows what can limit your throttle and it comes down to exhaust temp, turbo fmem, or injector limit look at the pic below
    Next time you log you might try to remove as many channels as you don't need and see if your polling speed improves? Is 330lbs/hr 95% duty cycle on your injectors?
    Jul 2011
    Tampa, FL
    275
    The entire fuel system is stock. The only physical change to this car outside of how it was delivered from the factory is the fact it has E85 in the tank. I have not added or removed anything from the car.
    It's currently using 85% DI blend above 7k rpm.
    The stock tables are set to 90% and I ASSumed it would automatically blend down if it's running out of DI capability. It is on E85 so perhaps its maxing out the DIs and shutting the throttle as its hitting the limit of those?
    I wonder if I set the max blend above say 6000 to 80% that was it starts to use the PIs ahead of the DI limit?
    The 7k trans limit RPM is interesting. Not sure where that comes from
    8.3@167mph
    2014 Mustang GT
    6.87@200mph
    Jul 2011
    Tampa, FL
    275
    Hmm. Ok. I will look into that. Would be nice if the ETC source said Injector limit so I knew what the computer was actually thinking and why it decided to close the throttle only on the 3-4 shift
    8.3@167mph
    2014 Mustang GT
    6.87@200mph
    do you even have enough pump for e85.
    Jul 2011
    Tampa, FL
    275
    Quote Originally Posted by superman07 View Post
    On a bone stock car with 0 performance modifications? I believe so. Fuel trims are perfectly in line, fuel pressure isn't dropping. No reason to suspect the stock fuel pump is at its limits
    8.3@167mph
    2014 Mustang GT
    6.87@200mph
    Jul 2011
    Tampa, FL
    275
    Fixed!
    Did a handful of back to back pulls today and no issues. I believe the issue was rpm element limit and a couple other limiters that I had raised, but not raised enough to consistently allow 7500+ rpm shifts.
    Also fixed the polling in the log and it's MUCH more responsive now.
    Added the fixed file in case anyone wants to compare file 7 to 9 to see what needed to be changed.
    7600rpm shifts no problem
    8.3@167mph
    2014 Mustang GT
    6.87@200mph
    Advanced Tuner small tuner's Avatar
    Nov 2015
    271
    can you post the log?
    Turbocharged COYOTE
    PM for E tune / Remote Tuning
    [email protected]
    Jul 2011
    Tampa, FL
    275
    Quote Originally Posted by small tuner View Post
    The only log I have with the fix is about a 2 hour drive log which is pretty big. I'll try and get a smaller one later
    8.3@167mph
    2014 Mustang GT
    6.87@200mph
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    Quote Originally Posted by Justinjor View Post
    you can trim any portion of a log
    Log File > File Exporter > Visible range ( use your mouse wheel or the zoom feature to choose that)
    Jul 2011
    Tampa, FL
    275
    Quote Originally Posted by LastPlace View Post
    well that's super handy. Ty!
    Log attached. Happy shifting now
    8.3@167mph
    2014 Mustang GT
    6.87@200mph
    I don't wanna hijack with unrelated stuff, but how do you add a blank line between groups of things you are logging in the vcm scanner?
    Jul 2016
    613
    Right click on the channel list and you’ll see where it says move things up and down just move things down to make a space
    Nov 2015
    271
    how to get ride of shift modulation and spark reduction TQ source between shifting. have you notice that
    Turbocharged COYOTE
    [email protected]
    Jul 2011
    Tampa, FL
    275
    I have not messed with any of that yet. Given that the transmission is stock, I think it's wise to leave the factory torque management active between shifts so this thing (hopefully) lives a long and fruitful life
    8.3@167mph
    2014 Mustang GT
    6.87@200mph
