Results 1 to 10 of 10
Thread: LSA with LS7 Card Style MAF And 102mm Tube - Anyone have an HPT file?
    Sep 2020
    36
    Hi All,
    I have got my LS7 MAF + 100mm tube working well and now need to look at scaling it to the stock tuned 2013 CTSV E67 ECM.
    (MAF CARD - GM Part#23256991)
    Has anyone got a similar setup that has been tuned and finalized and can share an HPT file, so I can get a base MAF scale extracted and installed.
    I have currently installed a MAF scale from a 2013 Camaro Z28 (LS7 engine) which is felling better but is still not quite right. (Fuel trims are still adjusting a little too much)
    Thanks in advance
    Craig
    Sep 2020
    36
    Thanks for that, very interesting
    Sep 2020
    36
    No one else have similar tune?
    7,648
    Create the chart, collect the error data, apply the error % to your file. No one else's file will be correct for your particular unique combination of parts and vehicle condition. Just tune it. This is what 'tuning' is.
    Sep 2020
    36
    Good call...
    2,742
    The type of MAF doesn't matter as much as the tube it's installed in.. Bends before/after, size of tubing, clocking, etc.. all matter. Make sure IAT1 is calibrated. Off the top of my head I don't know if the LSA maf and LS7 card style maf uses the same IAT fuction.
    Tuner at PCMofnc.com
    Sep 2020
    36
    Cheers, I have calibrated IAT1 from a known source (E67 to LS7 MAF table)
    Oct 2020
    23
    This was the sensor I got that correlated to the LS7. Download the stock 2015 Camaro ZL1 tune from the repository to get the MAF curve, then be prepared to estimate the airflow change if your tube is not stock dimensions or shape.
    General Motors 15865791, Mass Air Flow Sensor
    https://www.amazon.com/gp/product/B008Y8RNNM/
    Tuner K Rob's Avatar
    Apr 2021
    Oklahoma City, OK
    88
    you all rock
