Results 1 to 3 of 3
Thread: VSS pin location for black box 4L60 to 4L80 swap?
    Jan 2021
    Hi Guys,
    Posting for my dad as hes wiring up a trans swap.
    Details: 1997 Tahoe black box originally 4L60 now with 4L80
    Questions
    1) Trans swap harness has 2 extra wires for added VSS...what pins do these go to in 1997 Tahoe PCM?
    2) Whats the best path to reflash the black box to a 4L80 program?
    Thanks!
    Feb 2016
    Texas
    534
    lt1swap.com All the pinouts you should be needing for the black box.
    97 ext cab short bed silverado 5.7 411 swap, edelbrock 29135 intake, lightly ported 906 heads milled .035 thou. factory press in rocker studs & rockers, comp 787 retainers & stock locks, ls6 springs. Comp cams 08-503-8 T56 swap
    86 SWB crate vortec 5.7/th350 The wife's truck
    Jan 2021
    So for the 97, the pin out shows C3 gray plug uses pin 7 for ISS on 4L80 only. But the conversion harness includes 2 additional wires, so is it for Pins #7& #8 or #7 and the other new wire goes somewhere else? I don't see any other pin locations that call out a pin location used by 4L80 only (per below link from LT1swap)
    https://lt1swap.com/1996_vortec_5.7/index.htm
