E92 Bench Harness
Anyone have the pin outs to make a E92 bench harness? Need Bat+ Ign+ Grounds CAN+ CAN- and which connectors, Blue, Black, Gray.
TIA
Here is how mine is pinned. All locations are on X1 (the blue one)
Pin 22 - Ground
Pin 39 - Can +
Pin 40 - Can -
Pin 51 - Switched Ignition Voltage
Pin 52 - Battery Voltage
Pin 70 - Serial Data Wake Up (switched voltage)
Well crap. I guess I don't have an E92 then. I was given a computer and connectors out of what I was told was a 2014. I just thought it was a E92. Must be a E78 out of a 14 with a 6.0 because my blue connector only has 56 pins. Thanks for that info though. I'll keep that for when I do get my hands on a E92 and a connector. I've been known to use individual wires to read and flash them too.
