Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: LT4 FUEL PUMP UPGRADE. What needs to be updated??
    Jun 2018
    609
    Is there anything in the tune we need to update? I have an LT1 car and I copied the fuel pump data from a Z06. I'm not getting any extra high side fuel pressure. I tried another LT4 pump and it's the same thing. It's plugged in for sure but the fuel rail pressure is about the same as the low pressure side. We checked to make sure it's plugged in, the car ran fine with the LT1 stuff in it the day before. Can't be in the tune can it?
    Aug 2014
    Central, LA
    737
    What all values did you change?
    Aug 2009
    Calibrating
    3,373
    Make sure the axis is the same as the stock OS, I do change these from time to time, but you have to know what you’re doing or you’ll have problems
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Dec 2015
    Miami,Fl.
    290
    Post tune.
    2023 Ford Maverick 2.0T AWD
    Jun 2018
    609
    VIC.LT4.011.lt4fuelupgrade.hpt
    So we updated everything we can find different under the fuel pump page. Axis has been updated as well. I was thinking maybe the lifter plunger that rides the cam needed to be changed with it? But I haven't seen anything about that anywhere and I'm pretty sure we've done this swap before.
    Dec 2015
    Miami,Fl.
    290
    Does the car have an aftermarket cam with 32% fuel lobe?
    Jun 2018
    609
    Yes, we took the lash cap off being that it was an lt4 pump. We had one on when it was the LT1 pump
    Dec 2015
    Miami,Fl.
    290
    Quote Originally Posted by JASON11WS6 View Post
    Needs the oem ls7 (.060) lash cap to function properly.
    Aug 2014
    Central, LA
    737
    Quote Originally Posted by HeavyChevy305 View Post
    Not necessarily. My lt4 hpfp measurements require no cap.
    Aug 2009
    Calibrating
    3,373
    When I’ve used them I’ve used the ls7 which is shorter then some there were shearing the 2 HPFP bolts off!
    I currently don’t have a lashcap on my personal lt4 Pump setup with 32% fuel lobe.. get my extra fuel from PI
    14 Gen 5 Viper
    Jun 2018
    609
    Tune looks okay?
    Jun 2018
    609
    So we put the LT1 pump back in with the LT1 tuning and it runs fine. Low side is a little out of steam but the rest looks good. Might just get a low side upgrade and go from there with the LT1 pump. Anyone look at my tune and make sure I didn't do anything that would have caused it to not work?
    May 2006
    Waterbury CT.
    293
    I ran in to this before with a 2014 model and Higgs Boson helped me so I am paying it forward.
    On the 2014 only, you can NOT modify the High Pressure Pump/Peak Duration table when loading all the LT4 data, return it to stock and all will be well.
    Ted.
    Dec 2015
    Miami,Fl.
    290
    Quote Originally Posted by JANNETTYRACING View Post
    Ted.
    Yup. Happened to me on a l83 Silverado when they switched to a LT4 fuel system.
    Jun 2007
    Finland, Europe
    549
    Ted.
    Exactly.
    Jun 2018
    609
    That, makes some sense. Thanks jannetty.
    Dec 2017
    Sugar Land, TX
    11
    I just installed the DSX Low Side system on my 2017 Z06. Pump definitely works and turns on as soon Fuel Mode hits "High Flow". Now the low pressure looks great, it's the high pressure that's the problem. I'm running E30, just like I was before the added pump and high side would stay pretty close to the desired pressure under full throttle. Now the high side pressure drops to 1,000 psi (even 800 sometimes). AFR (Lambda) is constant at around 0.82 at full throttle even though the high side pressure is really low. I've only done limited runs on the street in 2nd and then in 4th gear. As soon as it goes into "High Flow" mode, the requested low side pressure jumps to 73 psi and the aux pumps turns on. Low side pressure jumps to 86 psi or so, confirming pump operation. At the same time high side pressure begins to drop. After 1.5s in High Flow mode, the high side pressure is right at 1,000psi and low side has dropped to 76 psi. That's as far as I went before letting off the gas (4th gear (auto), 5,000 rpm, 96 mph). Lambda solid at 0.83.
    Has anyone seen similar results? High side pressure being that low is pretty scary, but at the same time AFR is still good.
    PS - Injector Pulse Width is quite a bit higher than previously. It's up to 10-11 when the aux pump kicks on. Didn't change anything else, so this is a real mystery. Any help would be appreciated.
    Aug 2009
    Calibrating
    3,373
    Your injector PW is about 2x higher then it should be
    14 Gen 5 Viper
    May 2006
    Waterbury CT.
    293
    Maintaining low side pressure is a requirement to support the high side pump.
    BUT!!! it has almost no effect on high side being able to provide additional fuel volume required too support your build on E fuels, I suspect you are about 15 psi boost.
    Any time high side drops injector opening time will increase.
    Injector opening time is not related to low side pressure.
    Ted.
    Dec 2017
    Sugar Land, TX
    11
    Thanks for the replies. This is the funny thing. Without the low side pump, the PW and HPFP pressures are much closer to "normal". By normal I mean 5-6 PW and much closer to the requested 2,900 psi requested pressure. Nothing else has changed, other than the addition of the low side pump.
