That indicates a possible problem with what the fuel pressure sensor is seeing vs what the high pressure pump is seeing.
Prior to installing the aux pump, low side would drop into the 40's (E33). Attached is a 1/4 mile log before installing aux pump. This one shows pressures getting pretty low yet AFR still looks pretty good.
I had another run where the car shut down and threw the low fuel pressure code (Also attached). I lowered the E to E30 for that run.
The smaller file is the one where car shut down and the larger one was the good run.
Gonna take car into my tuner on Tuesday to see if he can address the high-side drop. DSX was no help. Dave says he has seen this before (high side drop when aux pumps kicks in) but no idea how to fix it. Was quite surprised with all the tuning these guys claim!
"Gonna take car into my tuner on Tuesday to see if he can address the high-side drop. DSX was no help. Dave says he has seen this before (high side drop when aux pumps kicks in) but no idea how to fix it. Was quite surprised with all the tuning these guys claim!"
67John98
Were you ever able to get this resolved?
