Results 1 to 8 of 8
Thread: LS1 to LS6 injector tuning changes
    Mar 2019
    Auckland, NZ
    43
    Hey all.
    I have changed the injectors in my engine from the 26lb LS1 units to the 29lb LS6 units.
    In the fuel/general tab in HPTuners what fields need changing (other than below)
    • Flowrate vs KPA
    • Short Pulse Limit
    • Min Injector Pulse
    • Default Injector Pulse
    • Offset Vs Volts vs VAC
    • Short Pulse Adder
    Does anyone have a stock LS6 tune file that I can copy the fields from (or) can someone confirm if they are as follows...
    Flowrate vs KPA = 3.671875 3.6953125 3.71875 3.7421875 3.765625 3.78125 3.8046875 3.828125 3.8515625 3.875 3.8984375 3.9140625 3.9375 3.9609375 3.9765625 4 4.0234375
    Short Pulse Limit = 3.921
    Min Injector Pulse = 1.246
    Default Injector Pulse = 1.246
    Offset Vs Volts vs VAC = long table
    Short Pulse Adder = long table
    Cheers
    Quintin
    Download a 2004 corvette z06 stock file and compare to yours. Everything under general, Fuel tab should be copied over. If you need more help, contact me
    Calibrator By Day, Student of the Game at Night.
    www.LSXedit.com
    Want to Learn Hands On? I Offer Remote Tuning Email Me at [email protected]
    TEO TUNED
    You Can View Most of my Library on Instagram
    Website Coming Soon...
    INSTAGRAM: @TEOTUNED
    Mar 2019
    Auckland, NZ
    43
    405
    2,326
    01-02 F-bodies LS1 and 01-04 Vette LS1 and 02-04 LS6 both use the exact same injector. Same part number. Both calibrated by GM engineers. Different injector data for each vehicle type. Just throwing this out there.
    Feb 2018
    NC
    53
    correct me if im wrong but the tunes are different because f bodies have fuel return from the fuel rail and vettes have single line at fuel rail (returnless)and do return from the filter
    Feb 2016
    Texas
    534
    used a fuel filter/regulator which has the return port built within the filter itself. It used to be regularly used for ls swaps and some still do use them. While they do return at the filter its still a regulated flow rate. And doesn't require a rising injector flow rate. Very possible im wrong also....
    97 ext cab short bed silverado 5.7 411 swap, edelbrock 29135 intake, lightly ported 906 heads milled .035 thou. factory press in rocker studs & rockers, comp 787 retainers & stock locks, ls6 springs. Comp cams 08-503-8 T56 swap
    86 SWB crate vortec 5.7/th350 The wife's truck
    405
    2,326
    Quote Originally Posted by It Will Run.Maybe View Post
    Nope 98-02 F-body LS1 have a returnless fuel rail. If they did their IFR would have no slope but they do. Both use a sloped IFR and they are not different by much, but different .4-.5 lb/hr in the IFR. Ok so they maybe have different fuel pressure because one regulator is in the tank and one is in the filter. So then explain why the Offset VS Volts is different, Short Pulse Adder is different, Minimum Injector Pulse is different, Default injector pulse is different. These are injector characterizations that wouldn't change with slight different fuel pressure. I guess the point I'm trying to make is people go ape shit about not having exact injector data yet here we have the same injectors used in two different platforms using the same OS from the same OEM with different characterizations. Just saying.
    7,649
    An example with less potential for ambiguity. The only differences are cylinder bore and cam profile (5.3L has DOD/AFM). Same pump, lines, rails, injectors, intake, throttle body, air filter, MAF, wiring harness, alternator...
    2006 Trailblazer 5.3 1GNET16M466118580 1212321883.hpt
    2006 Trailblazer 6.0 1GNET13H762320408 84701868.hpt
    Some tables have insignificant differences but others like the Offset tables are pretty radically different.
    Sometimes the same injectors (12580681) used in the same platform with the same fuel system get different injector data. Maybe the two cals were done by two different teams who had different ways to approach things, or maybe it was the same team doing it on different days trying to solve a different set of problems. Who knows.
