Results 1 to 8 of 8
Thread: 6th gen SS 6.2 Flexfuel Startup timing in the cold
    Jan 2021
    6
    as the temps have cooled down I have noticed that when the car starts in the morning it struggles and cranks for about twice as long as if the car was warm. I did add timing to the startup table for colder coolant temp ranges. What is everyone else doing in the table. My next step was to add 10% to those cells and see if that helps any. Please let me know what you guys are doing.
    I live in Texas so it never really gets that cold but it is in the 30's in the early mornings.
    Aug 2009
    Calibrating
    3,373
    DI always has longer cold cranks Bc it has to build adequate amount of fuel pressure before it will fire
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Cranking eq ratio alcohol table needs adjusting. Try adding 10%.
    Jan 2021
    6
    Quote Originally Posted by 32vape View Post
    Should I go 10% across the board or below 75*?
    Dec 2019
    Boerne, TX
    117
    Bump this. I live in TX too and it's been low 30s upper 20s for a while and my truck cranks for about 4-5 seconds above 60% ethanol. Looking for a solution.
    13,557
    It's E60 in cold weather, there is no easy solution.
    You should try E70 when it was like 0 to 10 degrees outside last year, now that took a while. I don't run an E85 blend in the winter anymore.
    Jan 2021
    6
    I was thinking the same thing. If the bumped cranking FP doesn't work I am just going to run 93 in the winter. I can not put the extra power down anyways. The car just spins on cold rubber.
    Dec 2019
    Boerne, TX
    117
    Quote Originally Posted by bjbonnette View Post
    Yup. Same here, my Michelins Defenders have been feeling awful lately. Seems futile!
