Thread: p01 ecm max injector flow rate?
    Dec 2012
    235
    So I scaled Id1050's into a p01 and it looks like they are not limited to 63lb/hr. I was able to scale the 1050's. Is this true? Usually I would have to double stoich with early Ecm's.
    Aug 2009
    Calibrating
    3,373
    256 lb hr limit
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    13,559
    You can put up to like 256lb/hr injectors in them with the right data.
    Should be no need to scale those ID 1050's on that computer. If you have all the injector data you are good to go.
    Dec 2012
    235
    Awesome! I did use all the Id data. I was just kinda surprised that it let me go that high in the flow rate table. Thank you guys for verifying.
