with this tune im running 14.5@ 97ish everything stock including air filter, would just like to make sure it seems reasonably safe from another set of eyes thanks in advance.
You have a log showing the read equivalence ratio in lambda?
I got the stoic set at 12.96 for the e30 which is equivalent to 14.7 if that?s what you mean.
The log doesn't show if its enriching or not when you go wot
The main reason I ask is it looks like the max accelerator position shows 80 percent, you have enrichment set stock at 90
🤔 I?ll have to check on that. Thanks for pointing that out.
