Results 1 to 7 of 7
Thread: 2006 Tbss 408 lsa
    Jan 2021
    3
    2006 Tbss 408 lsa
    Will the stock e40 ecm from the trailblazer ss take the OS upgrade so I?m able to switch to 2bar map or 2.5(boost) sensor . Because it?s doesn?t give me an option currently ?
    13,564
    Are you in advanced view under the edit tab??
    Jan 2021
    3
    Im not the tuner and I?m new to hp tuners . I just know my ecm doesn?t have the option currently and wondering will my e40 take the os upgrade software or is it even available for it
    13,564
    I can't tell you without you posting the tune file here.
    So that is why I asked you to check the "view" in the edit tab of the editor. Look there to see if you are in basic view or advanced view. The OS options do not show up in the basic view.
    Nov 2006
    2,739
    Some 06 TBSS's do not have a 2 bar option available. We could do a GM SPS flash to the latest OS that will allow it. I don't think I would try over writing it. It might work but most of the time does not on Gen 4 stuff.
    Tuner at PCMofnc.com
    Jan 2021
    3
    Hey can u tell me what?s the latest OS. Or give me a reference #
    7,619
    ---> https://tis2web.service.gm.com/tis2web/
    Paste your VIN into the little box, select 'PCM/VCM Powertrain/Vehicle Control Module' and follow the prompts.
