Results 1 to 3 of 3
Thread: 2013 Ford Mustang Spare PCM (VIN rewrite)
    Aug 2013
    13
    Hi, I have a 2013 Ford Mustang v6 from a customer, he had a problem with the old PCM shutting down the throttle so he bought a spare PCM... I paid 4 credits so we can pull the info from the stock one, modify some things on it and then write it on the spare one...
    It didn't started and I did program the key with my key programmer and the car started with the spare pcm...
    Last time I did a PCM swap was on a 2007 ford mustang and it allowed me to change the vin and I had no problem at all (I have the license for all 2007 mustangs)
    LONG STORY SHORT, I have now the ABS light and the tractions lights on because the spare pcm vin is different than the OEM ABS module vin...
    I need to change the vin on the spare pcm so it will work as it should... It's driving me crazy and I know it can be done because I did it in the past...
    Need some guidance or advice to achieve this... thanks!!!!
    I have the exact same problem on a 2013 GT. From all the searching it looks like HP Tuners used to support vin edits but removed it a few years ago. I now have a 2013 GT with ABS and PCM that don't match the car's VIN, however it does work.
    Forscan can program VIN/VID block on the 2013 mustang pcm. I recommend a wired ELM 327 adapter for programming.
